1995 Toyota Corolla, 175000 miles, one day my car won’t start, so I tow the car to near Firestone location. They change ignition coil and rotor. Also same time they changed valve cover gasket and they did fuel system tune up. After that I was getting jerks during gear shifting, so they said I need to change distributor, distributor cap, spark plug and wire and all of the above cost was $1400. I told them to put all my original part back and I did install brand new distributor, rotor, coil wire and plug by my self.
Problem is when I am driving car, it suddenly loose power and shift gear to first. If I stop and start again, it will run normal. It does not do all the time but more often so I can't ignore it. Also on highway some times I get two or three jerks and run again normal.
Could you please tell me what could be the problem?
Thanks for providing really good service.
SPONSORED LINKS
Wednesday, May 23rd, 2007 AT 12:20 PM
