I believe this model uses a pressed in bearing.
Raise vehicle, put on stands. Grasp tire and pull/push bothe horizontally and vertically looking for any movement. If movement, try to determine if it is ball joint, tie rod, control arm bushing, if not then probably a wheel bearing.
I would remove the knuckle take it to a shop, and have them press in new bearings.
Also inspect the knuckle bearing area for wear/cracking.
SPONSORED LINKS
Thursday, October 23rd, 2008 AT 6:20 AM
