Raise and support the vehicle and remove the wheel, caliper and disc.
Loosen the 2 nuts on the lower side of the shock absorber. Do not remove the 2 nuts and bolts.
Remove the cotter pin and nut from the tie rod end.
Remove the tie rod end from the knuckle using a joint separator or equivalent.
Remove the bolt and 2 nuts holding the bottom of the ball joint to the control arm and separate the arm from the knuckle.
Remove the 2 nuts from the steering knuckle. Place a protective cover or shield over the CV boot on the driveshaft.
Using a plastic mallet, tap the driveshaft free of the hub assembly.
Remove the bolts and remove the axle hub assembly.
Clamp the knuckle in a vise with protected jaws.
Remove the dust deflector. Loosen the nut holding the ball joint to the knuckle. Use a ball joint separator tool or equivalent to loosen and remove the joint
Use a slide hammer/extractor to remove the outer oil seal.
Remove the snapring.
Using a hub puller and pilot tools or equivalents, pull the axle hub from the knuckle.
Remove the brake splash shield (3 bolts).
Use a split plate bearing remover, puller pilot and a shop press, remove the inner bearing race from the hub.
Remove the inner oil seal with the same tools used to remove the outer seal.
SPONSORED LINKS
Friday, December 18th, 2009 AT 7:42 PM
