Tires and Wheels problem
1995 Toyota Corolla 4 cyl Front Wheel Drive Automatic 1ooooo miles
change front wheel bearing 95 corolla
Tuesday, May 13th, 2008 AT 3:17 PM
MECHANIC
Hi there,
This will require a hydraulic press and special tooling, if you have access to this equipment, re post and I will advise, otherwise you will need to get your local mechanic to do this job.
