1995 Toyota Corolla Temperature Gauge
MORANRD
  • 1995 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 119,000 MILES
In the morning the average temperature is 32 degrees. Should it take 15 minutes of driving time for the Corolla to produce enough heat for the inside heater to be effective?
Tuesday, January 6th, 2009 AT 12:44 PM
MMPRINCE4000
  • 8,548 POSTS
No, I would change the thermostat and flush the cooling system. Refill with 50/50 mix.
Wednesday, January 7th, 2009 AT 8:33 AM
MORANRD
Thank you for your reply!
I am taking the Toyota to my mechanic. He confirmed what you said.
Why 50/50 mix?
Wednesday, January 7th, 2009 AT 8:38 AM
MMPRINCE4000
  • 8,548 POSTS
Unless you are in an extremely cold climate (Alaska, Northern U.S, Canada) a 50/50 mix will protect to 30 below zero.
If you are in a colder climate, then the MAXIMUM you can mix is 70/30 (antifreeze/water). Beyond that you will not gain any additional protection, and will actually lose cooling system effeciency.
In Alaska and Northern Canada, all cars have a block heater installed, which plugs into a 120V outlet and circulates heated coolant throughout the block to ease starting and protect against coolant freeze.
Wednesday, January 7th, 2009 AT 5:06 PM
