1995 Toyota Corolla starter
RRCR
  • 1995 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 230,000 MILES
I start my car and what happen is the starter didn't back to normal it keeps on even the engine is running, so I turn off the engine but still starter keeps on, so I remove the negative side of the battery to stop the starter from running. Everytime i'll put back the battery it's start immediately.
Saturday, September 27th, 2008 AT 11:54 AM
KHLOW2008
  • 41,814 POSTS
Hi rrcr,
Either the ignition switch is faulty or the starter solenoid is stuck.
Unplug the ignition switch wire connector and if the problem goes away, replace the switch.
Sunday, September 28th, 2008 AT 3:24 AM
