1995 Toyota Corolla remove starter
VMSESSIONS
  • 1995 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 158,000 MILES
How do you remove the starter
Saturday, August 15th, 2009 AT 12:03 PM
STEVEW84
  • 673 POSTS
Disconnect battery ground cable.
Disconnect the IAT sensor connector
Remove air cleaner hose clamp bolt.
Remove air cleaner cap clips.
Disconnect the air cleaner hose from the throttle body, and remove the air cleaner cap together with the air cleaner hose.
Remove the wire clamp.
Disconnect electrical connectors from starter motor
Remove starter motor attaching bolts, heat shield (if equipped), then the starter motor.
Saturday, August 15th, 2009 AT 9:14 PM
