If shifting is controlled by a cable (called a TV cable), then the cable may need adjusting.
Cable controlled trans. Have a cable that connects to the throttle body cam and then to the trans.
If controlled by vacuum, then check for leaks in the line.
This is something you want to get repaired quickly, if hydraulic pressure is low, it may beging slipping and that can cost you a new trans.
SPONSORED LINKS
Wednesday, May 26th, 2021 AT 6:36 PM
