replaced the clutch master cylinder and slave cylinder, but cannot shift.
Mar 1, 2017 at 1:39 AM
HMAC300
✓Experienced Mechanic
if it will shift while engine is off then it is probably a clutch problem or air in system. also, check cables or linkage for proper adjustment or stretched cables. if it will not shift with engine off then it is either a transmission problem like a synchro/shift fork etc assuming linkage is okay.
