1995 Toyota Corolla
MIKENMATT
  • 1995 TOYOTA COROLLA
Drive Train Axles Bearings problem
1995 Toyota Corolla 4 cyl Front Wheel Drive Automatic
How do I remove the drive axle from the transmission
Saturday, October 31st, 2009 AT 8:26 PM
MMPRINCE4000
  • 8,548 POSTS
They are held in place with a "C" clip on axle shaft and they pop out.
Raise car, put on stands, use pry bar between the axle tripod and trans case, they pop out.
The BEST way to get them out is to use a slide hammer with a large "C" shaped attachment, insert between axle shaft at trans. And tripod, use slide hammer to pull axle out.
VERY IMPORTANT! Make sure to refill the differential fluid after axle is installed, and also change axle seals.
Sunday, November 1st, 2009 AT 8:26 AM
