1995 Toyota Corolla Possible Axle Replacement
1995 TOYOTA COROLLA
57,000 MILES • 4 CYL • FWD • AUTOMATIC
MINIVAK
Hi, I recently hit black ice in a parkinglot going about 10 mph. When I hit the curb as a result, I hit it at an angle. I impacted the curb and snow bank, there was no body damage, however the wheel that hit the curb is bent inward and towards the back of the wheel well. Now the car seems to be completely messed up, for i beleive the impact destroyed the suspention on that wheel, and bent the axel. Also the stearing wheel is completely out of whack. in order to keep the wheels straight the stearing wheel must be upsidown. Not to mention the wheels are no longer in sync. Also It make a horrible grinding sound when it moves. I was wondering what i may have done, and how much it would cost to repair.
Mar 2, 2009 at 1:28 PM
HELPING YOU
  • 100 POSTS
You should be able to see the parts that "gave" (compare to other side if not sure - parts aren't cheap - but HOSPITALS ARE LESS CHEAP!!!!
PLEASE don't continue to drive this car!
Mar 2, 2009 at 1:52 PM
MMPRINCE4000
  • 8,548 POSTS
As (help) said DO NOT DRIVE the car.
Possible problems are control arm, ball joints, steering knuckle, CV axle, strut, steering rack, tie rods etc.
Unless you intend to do work yourself, have car towed to reputable shop for estimate, but honestly, it may exceed the value of car depending on severity of damage.
Mar 3, 2009 at 12:31 AM
