In addition to what bluelightnin6 said:
It will prevent the ECM from going into closed loop, where O2 sensor feedback controls engine. This will increase fuel consumption, cause the engine to run rich and eventually ruin the convertor.
If you are having a overheating problem, removing the thermostat, is only a band-aid. Have the cooling system pressure tested and get the problem fixed.
Wednesday, April 22nd, 2009 AT 7:33 AM
