HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine Cooling
Thermostat
SPONSORED LINKS
1990 Toyota Corolla THERMOSTAT
CHRIS33141
MEMBER
1990 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
165,000 MILES
CAR TEMPERATURE GOES UP REALLY HIGH, BELIEVE IT IS THE THERMOSTAT THAT NEEDS TO BE CHANGED. WHERE IS IT LOCATED?
Tuesday, January 12th, 2010 AT 7:40 AM
BLUELIGHTNIN6
MECHANIC
Follow the lower radiator hose back to the engine and thats where the thermostat housing should be.
SPONSORED LINKS
Tuesday, January 12th, 2010 AT 9:47 AM
MMPRINCE4000
MECHANIC
On this engine it is lower hose that connects to thermostat housing directly under distributor.
Use a Toyota part and make sure the thermostat weep hole is pointing at 11:00 when installed, replace thermostat seal.
Tuesday, January 12th, 2010 AT 12:47 PM
Please
login
or
register
to post a reply.
Related Thermostat Content
1990 Toyota Corolla
1990 Toyota Corolla 4 Cyl 163285 Miles I Was Changing My Thermostat And And Bolt Broke Off That Te Thermostat Housing Attaches To....
Asked by
TANYE
1 ANSWER
1990
TOYOTA COROLLA
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
1994 Toyota Corolla Overheating With A New T Stat
My Car Was Overheating So I Replaced The T Stat And It Did Nothing, The Upper Hose Gets Hot But The Lower One Does Not. No Leaks, And No...
Asked by
mountainhomebands
1 ANSWER
1994
TOYOTA COROLLA
1992 Toyota Corolla Purging Air After Thermostat &...
I Replaced My Thermostat (it Was Periodically Sticking Open) With A Genuine Toyota Stat & Also Replaced The Lower Hose. The New Stat Had 82...
Asked by
keepitrunnin
1992
TOYOTA COROLLA
I Broke Screws Of Thermostat Housing, How To Replace
Hi I Own A Toyota Corolla 1995 Automatic With 155000 Miles On And Prtty Good Shape, A Week Ago Starting Overheating And They Recommended Me...
Asked by
gmante6309
TOYOTA COROLLA
Thermostat Replacement
I Was Wondering Where Exactly Is The Thermostat Located On The 1.6l Engine Of A 1996 Corolla?
Asked by
baker1996
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
How to Replace Thermostat
Thermostat Replacement Ford
Online car repair manuals
