HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine Cooling
Thermostat
SPONSORED LINKS
Thermostat replacement
BAKER1996
MEMBER
TOYOTA COROLLA
I was wondering where exactly is the thermostat located on the 1.6L engine of a 1996 corolla?
Tuesday, November 7th, 2006 AT 12:15 PM
BAKER1996
MEMBER
1996 toyota corolla with 195,000 and I was wondering where the thermosta was located on the engine
SPONSORED LINKS
Tuesday, November 7th, 2006 AT 12:17 PM
GEET
MEMBER
Its in the water pump just below the distributor
Sunday, March 1st, 2009 AT 11:16 AM
Please
login
or
register
to post a reply.
Related Thermostat Content
I Broke Screws Of Thermostat Housing, How To Replace
Hi I Own A Toyota Corolla 1995 Automatic With 155000 Miles On And Prtty Good Shape, A Week Ago Starting Overheating And They Recommended Me...
Asked by
gmante6309
TOYOTA COROLLA
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
1994 Toyota Corolla Overheating With A New T Stat
My Car Was Overheating So I Replaced The T Stat And It Did Nothing, The Upper Hose Gets Hot But The Lower One Does Not. No Leaks, And No...
Asked by
mountainhomebands
1 ANSWER
1994
TOYOTA COROLLA
1992 Toyota Corolla Purging Air After Thermostat &...
I Replaced My Thermostat (it Was Periodically Sticking Open) With A Genuine Toyota Stat & Also Replaced The Lower Hose. The New Stat Had 82...
Asked by
keepitrunnin
1992
TOYOTA COROLLA
1993 Toyota Corolla Removing The Thermostat
Engine Cooling Problem 1993 Toyota Corolla 4 Cyl Front Wheel Drive Manual If I Remove The Thermostat In My Engine Would It Affect Gas...
Asked by
vincexvi
1993
TOYOTA COROLLA
1990 Toyota Corolla Thermostat
Car Temperature Goes Up Really High, Believe It Is The Thermostat That Needs To Be Changed. Where Is It Located?
Asked by
CHRIS33141
1990
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Thermostat Replacement Dodge
Thermostat Replacement Chevrolet Blazer
Online car repair manuals
