1993 Toyota Corolla My Air Conditioning doesn't cool
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIMMYSALLA
I last year i bought this car and the A/C was not working. So i checked the pressure on low side valve and saw that there was no coolent in it. At this stage it had R12 valve. I put a r134 valve on it and filled with r134 coolent it was working fine. But now it doesn't cool at all. The compressor start but doesn't cool. I checked pressure and it is in 70psi. suggest me what shud i do to get it working.
Regards,
Jimmy
Apr 19, 2009 at 2:50 PM
MMPRINCE4000
  • 8,548 POSTS
When you switch to R134A you should also change all the seals and use a different oil.
You most likely have a leak somewhere.
Best advice it to take to an AC shop and have it repaired, or change all the seals, but it is illegal to vent 134A to atmosphere.
Apr 20, 2009 at 12:29 AM
