car has recently been emitting smoke.
200,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
METATARSAL 5
Car has been running a little rough as if losing compression.
Apr 4, 2015 at 11:31 AM
CARADIODOC
  • 34,415 POSTS
Low compression will make an engine run uncommonly smoothly. Rough running is usually caused by a misfire, and that's what should be diagnosed. How long since the spark plugs and wires were replaced? Other than that, I need test results to analyze. I also need to know the color of exhaust smoke to determine the cause. It could be white, blue, or black.
Apr 4, 2015 at 12:14 PM
METATARSAL 5
White
Apr 4, 2015 at 8:52 PM
CARADIODOC
  • 34,415 POSTS
White smoke from the exhaust is a sign of burning engine coolant. That is caused by a leaking cylinder head gasket. Your mechanic can perform a chemical test at the radiator that will confirm a leaking head gasket about 95 percent of the time. You can also add a small bottle of dark purple dye to the coolant, then search a day or two later with a black light. The dye will show up as a bright yellow stain that you can follow back to the source. If the head gasket is leaking, you'll find the dye inside the tail pipe.
Apr 6, 2015 at 10:20 AM
