1993 Toyota Corolla burning oil
AUSTIN02
  • 1993 TOYOTA COROLLA
  • 4 CYL
  • 192,000 MILES
My Corolla is burning through 2-3 quarts of oil every month. What might be the cause and what is the cost of possible repairs? Thanks
Monday, September 21st, 2009 AT 10:53 AM
What you need to do here to determine the problem is do a compression check and follow it with a cylinder leak test to pin point where-could be valve seals/stems/guide/rings/cylinder wear -For the cost it varies with location-hourly labor rate could be $70.00-$130.00 USD per hr.
Monday, September 21st, 2009 AT 11:35 AM
MMPRINCE4000
  • 8,548 POSTS
Also check for leaks, are you seeing blue smoke in exhaust?
Wednesday, September 23rd, 2009 AT 7:46 AM
