The lower fitting on filter is inverted flare, make sure it is not stripped, the top is a banjo and must have a copper washer on top and bottom.
Other leak sources are rubber hose to fuel rail, connection to fuel rail, and injector seals.
The lower fitting to filter is most common.
SPONSORED LINKS
Saturday, April 3rd, 2010 AT 8:18 AM
