1992 Toyota Corolla Engines hesitates briefly when cold
EPSILONE
  • 1992 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 230,000 MILES
Hi, a few minutes after my engine has been running it goes through a very brief period of hesitations and recovery. After that the car runs fine. When the air is colder, more time transpires before the hesitations begin. What could it be?
Sunday, March 22nd, 2009 AT 2:32 PM
MMPRINCE4000
  • 8,548 POSTS
I would tune it up, plugs, wires, cap and rotor. If that has been done, then check fuel pressure with mechanical gauge and replace fuel filter and air filter.
The car runs off a set algorithim prior to going into closed loop (O2 sensor reaches 600 degrees and coolant temp reaches 140 or so), after that the ECM controls engine via sensor feedback.
Also check base timing (10 degrees BTDC) with diagnostic port shorted TE1 and B1.
Monday, March 23rd, 2009 AT 5:56 AM
