1991 Toyota Corolla I dont know if this is a tire, shock or
SHENNEL
Tires and Wheels problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Manual
I drive a toyota corolla XL wagon, 1991 model. It uses leaf spring at the back and the shocks are automatic, I have used two set of back tires in less than two months and this is not supposed to be so. The tires wear quickly and i noticed that when ever i am driving and i drive into a small pothold or over a stone the two back tires sway to the side and i lfeel the car shifts too. Please what could be the cause of this? Please write back.
updated 10-21-09
so do you think it has nothing to do with the leaf spring? I checked the two shock absorbers and i found out that when i exert a force on them one is working well and the other when pressed down it doesn't return to its normal position. Is it advisable to use a fairly used shocks? most new parts here are china inferior products, so they don't tend to last as compared to the used ones. Please i need your response and if there is any materials you can help me out with i will be extremely grateful. Thanks again
Warm Regards,
David
updated 10-23-09
How are you doing and how is work going for you? Please i would like to ask if it is possible to change the leaf spring and the axle attached to it to a spiral spring type. Please i would like to know if this is possible? But the limitation is that they will have to drill holes and weld for this to work. Please i will like your advice on this? What are they positive and negative effects? Please reply?
Oct 20, 2009 at 9:48 PM
MMPRINCE4000
  • 8,548 POSTS
Have rear inspected for broken leaf brackets, but it sure sounds like a welded bracket or suspension component has failed.
Oct 21, 2009 at 1:48 AM
MMPRINCE4000
  • 8,548 POSTS
Could be a leaf spring problem, you would have to inspect the rear. It is possible a leaf is broken, or a U bolt is loose, broken.
If you have access to a junk yard there, it would be your best resource for used parts, and generally Toyota parts last a long time.
If you can't find any good used parts, you will have to get new ones.
Where I live, 1991 wagon parts are extremely rare, but sedan parts are generally easy to find.
Oct 22, 2009 at 2:58 AM
MMPRINCE4000
  • 8,548 POSTS
updated 10-23-09
If you are asking that you want to change the leaf springs to coil springs or coilovers?
It is possible, but unless you can find a conversion kit, I would be a bit dubious, it would take a lot of fabrication and would have to be perfectly aligned.
This conversion would most likely cost a LOT of money.
Oct 27, 2009 at 3:44 AM
