Engin dies when the key is released to the "run" position. It will continue to run as long as the key is in the "start" position.
His advice was just as I thought. Ing Switch!
I replaced the Ing. Switch today with no change!
Fuel is ok, Battery ok, No change when jumping from another car. Alt has not been tested by I'm not concerned about the Alt. Should I be?
5 volts out of the coil when key is in the "run" position.
Yes I need some direction!
SPONSORED LINKS
Wednesday, April 29th, 2009 AT 12:35 AM
