HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Electrical
Battery
Replace/Remove
1991 Toyota Corolla
ROGER C. MUNDT
MEMBER
1991 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
105,000 MILES
Need instructions to remove vehicle's battery
Sunday, June 21st, 2009 AT 1:22 PM
MECHANIC
Remove the negative battery cable 1st and then the positive battery cable-installing the battery connect the battery positive cable 1st and then the negative battery cable -make sure its properly tightened.
SPONSORED LINKS
Sunday, June 21st, 2009 AT 3:27 PM
Please
login
or
register
to post a reply.
Related Battery Replace/Remove Content
1991 Toyota Corolla 91 Toyota Corolla Wont Run After...
A Couple Of Weeks Ago Mmprince4000 Responded To My Question. Engin Dies When The Key Is Released To The "run" Position. It Will Continue To...
Asked by
jusaman
1 ANSWER
1991
TOYOTA COROLLA
VIDEO
Battery Replacement Toyota
Instructional repair video
GUIDE
Battery Replacement
Replacing a car battery is easy to do and will take about 20 minutes in most cases, this job can be done using everyday tools. Please wear protective gloves and eyewear when...
Already Replaced Battery Twice Still Dies
I Have An 1981 Toyota Corolla I Have Changed The Battery Twice And The Battery Has Died Both Times. I Took It Up To Autozone And Had Them...
Asked by
jhig1ey92
1981
TOYOTA COROLLA
How Do I Install A Battery Kill Switch In My 2010...
Which Wire Do I Splice The Switch Into, Inside The Steering Column?
Asked by
corollaS
2010
TOYOTA COROLLA
Battery Replacement?
How To Replace The Battery?
Asked by
tim139inna
1 ANSWER
4 IMAGES
2001
TOYOTA COROLLA
2005 Toyota Corolla Changing Battery
2005 Toyota Corolla Can I Change The Battery, Without Doing Any Harm? The Owners Manual States That A Professional Should Do It....
Asked by
hnhgrandma
1 ANSWER
2005
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Battery Replacement
How to Replace Battery
Battery Replacement Guide
Online car repair manuals
