Saturday, December 5th, 2009 AT 5:13 PM
Car stalled when driving at 35mph. Will not start now. Here's what I've checked. Fuel pump is working and has good pressure. Fuel at the rail. I have spark on all cylinders(not sure it's good but it's blue). Would not fire with starting fluid, not even a hit. Good compression, plugs are newer. When checking engine code, in park I get a regular flash that does not stop. If I put it in drive or reverse, I get code 51 A/C switch signal. AC button is off, May not work anyway. I ohmed the coil and the numbers are a little off but I still get spark. Any ideas? Thanks
