Engine Mechanical problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
what settings do I use to replace my timing belt. What are the timing belt settings for my 1991 toyota corolla
Friday, April 11th, 2008 AT 11:24 PM
MECHANIC
H there
Set the engine on TDC, 0 deg on the crankshaft pulley and with the small hole in the cam gar upper most you should be able to view the notch on the cam Post through the hole. There is a notch and a alignment mark on the crank shaft pulley as well.
Mark (mhpautos)
