1991 Toyota Corolla
GERSHCHIPATA
  • 1991 TOYOTA COROLLA
  • 4 CYL
  • 56,000 MILES
I when I start the engine in the morning, I experience some brue smoke coming out from the exhaust pipe, and then later it stops. What causes that?
Thursday, February 26th, 2009 AT 6:34 AM
MMPRINCE4000
  • 8,548 POSTS
The valve stem seals are worn out. They become hard and brittle with age and oil seeps down between the seal and gets into combustion chamber when car is sitting and accumulates in combustion chamber, when started it burns off as blue smoke.
You would need to have new valve stem seals installed. This requires a special tool set to do it correctly, so check with Toyota or trusted garage for cost.
Thursday, February 26th, 2009 AT 6:41 AM
