1990 Toyota Corolla Overheating
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
WANT2B
I have a 1990 Toyota Corolla that was overheating.
I flushed the radiator and removed the thermostat by recommendation to test if the thermostat was the issue and it still overheats only when I am climbing a hill.
There is little oil leaking on top of the transmission case just below the distributor. I had just replaced the distributor and plugs about 3 mths ago and the car drove like a dream. Now it misses because I hear a little clacking sound when I first give it the gas. Maybe the plugs are getting fouled by a oil leak. I removed the oil cap and there was some back pressure. Could this be a small leak in the head gasket? I have no water in the oil and not much loss of oil at all. It starts hitting the red while going uphill.
Oct 30, 2010 at 5:30 PM
JIS001
  • 3,412 POSTS
First of all, removing the thermostat is not a good diagnosis procedure especially if you are climbing a hill. I can take a 2011 vehicle, remove the thermostat, and it will also overheat climbing a hill, especially when you are going up a high elevation. Some people actually do not now the importance of a thermostat and it's function. When you remove the thermostat the water or coolant (whatever you have in there) just keeps circulating constatly. So when does the water cool? You may say the radiator's job is too cool it? Correct but when does it cool it? Well that is where the thermostat comes into play. The thermostat starts off closed and there is a reason why. The engine needs to heat up pretty quick so that other sensors and the CAT start to function properly. Once the engine starts to get hot, the coolant in the block starts to absorb the heat. When it reaches the temperature that the thermostat is suppose to open at say 180 degrees, it will open and let the cool coolant from the radiator in to the engine block while the hot coolant from the engine block is sent to the radiator. Once the cool coolant reaches the block and starts absorbing the heat from the block, the thermostat closes and now gives the hot coolant in the radiator time to cool off. Once it is cool and the coolant in the block absorbes the heat and the temp reaches our example of 180 degrees, the thermostat opens up once again and the hot coolant from the block goes too the radiator and the cool coolant from the raditor goes to the hot block to absorb the heat and the cycle repeats itself over and over again. If you have no thermostat, when is the coolant suppose to stay in the radiator long enough to cool down? It will not and it will cause you to over heat. Install a new thermostat and start from scratch again.
If you are over heating you may be hearing a pinging sound from pre detenation, meaning it is so hot, the gas is already igniting before the spark plug ignites it. So before the power stroke, the fuel is igniting during the compression and you are hearing the explosion when both intake and exhaust valves are closed. So the real question now is, when does your vehicle actually over heat? Are the fans coming on when they are suppose too? Are you running low on coolant? If you are running low on coolant where is it going? Do you see an external coolant leak? Let me know what you find after you install a new thermostat?
Oct 30, 2010 at 6:03 PM
WANT2B
I replaced the thermostat with new one and still overheats going up hill. I found the fan on relay switch doesnt open in a timely fashion so I jumpered fan to run when key is turned on. But the radiator heats up anyways. I have plenty power from the engine but some clicking noise from whenever I first accelerate or push on the gas. A little oil leak under the distributor.
The distributor was just replaced three months ago. Water pump appears to be working and moving water.
When you open the oil cap a little back flush occurs.
1. Overheats going up hill or pushing load on engine.
2. Slight oil leak under distributor.
3. A little clicking sound when accelerating.
4. When I place in neutral downhill engine cools quickly.
Any ideas?
Oct 31, 2010 at 5:25 PM
MMPRINCE4000
  • 8,548 POSTS
Start by checking your base timing, 10 degrees BTDC with diagnostic terminals shorted.
Check condition of timing belt.
I would flush the radiator and block.
Check oil pressure with mechanical gauge, this oil pump has a relief valve that can clog and lose oil pressure.
The dist. leak is caused by a bad O ring, replace and if it occurs again, use RTV to seal dist.
Nov 1, 2010 at 1:57 AM
MMPRINCE4000
  • 8,548 POSTS
Thanks for the positive feedback, I appreciate it.
Nov 3, 2010 at 12:23 AM
