1990 Toyota Corolla overheat
RONALD BRILLANTES
Engine Cooling problem
1990 Toyota Corolla V12 Two Wheel Drive Manual
when i do turn on the aircon of my car.. after an hour i feel like the engine runs not as smooth as when the car aircon is off.. is there any problem on my aircon?? it do cause to my engine oil to leak???
Nov 9, 2008 at 10:32 AM
  • 31,937 POSTS
Hi there,
The A/C will be a drain on the engine power and if the car is not in good tune the extra load caused by the A/C running will cause the engine to run a little rougher, so get the tune checked, if you have an oil leak this should be inspected and repaired, the A/C will not cause an engine oil leak under normal conditions.
Mark (mhpautos)
Nov 9, 2008 at 7:24 PM
