1990 Toyota Corolla Having issues when not fully up to temp
USMC2801
Engine Performance problem
1990 Toyota Corolla 4 cyl Front Wheel Drive Automatic 160K miles
Ok so my car has been acting when it starts to warm up, when I start it, it runs fine until the gauge starts going up and it runs fine when its fully up to temp, however in between it has a stutter at idle and sometimes even stalls out, but will start back up only to shut off when put back in Drive. Only way I can get it going is to start it and give it a lot of throttle for at least 15 seconds then put it in gear and go quick. I have taken off the throttle body already and cleaned that as well as the IAC and have replaced the CTS. Could this be an O2 sensor or EGR valve issue? I am just not sure which sensors are effecting the car during the warm-up stage that would effect the cars AFR to make it stutter or stall out.
Feb 22, 2010 at 1:45 AM
MMPRINCE4000
  • 8,548 POSTS
It would only be equipped with EGR if a CA. car. Federal and Canada were not.
O2 sensor needs to be at 600 degrees F to operate, below that the engine is run off a set of parameters in the ECM.
I would think it is a vacuum leak, fuel issue , or timing.
Check base timing, vacuum leaks and run a can of SeaFoam through tank.
Feb 22, 2010 at 2:07 AM
