AC not cycling could mean low freon-also for this How do I check the fuses that you can't see through. Toyota fusible links and miniature fuses is visible thru a window on top of it-
You must be talking about relays-it has a coil and switch side to it-normally the coil has 40-80ohms and the switch side is infinite meaning no reading because the switch is open this is how you check by using a DVOM. Or plain ohmmeter-
SPONSORED LINKS
Wednesday, February 13th, 2008 AT 4:55 AM
