1990 Toyota Corolla Cylinder Head
64BROHAM
  • 1990 TOYOTA COROLLA
Engine Mechanical problem
1990 Toyota Corolla 4 cyl Front Wheel Drive Automatic
I am replacing the cylinder head gasket and would like R&R instructions.
Saturday, December 19th, 2009 AT 10:21 AM
MMPRINCE4000
  • 8,548 POSTS
Really you need a repair manual, this is a big job.
Drain coolant
set engine to TDC #1
remove alt, WP pulley, dist.
Remove wiring to injectors, MAP and then fuel rail.
Remove intake and exhaust manifolds.
Remove timing belt.
Remove valve cover.
Screw a M6 x 1 bolt into hole in intake camshaft subgear.
Rotate exhaust cam 90 degrees and remove bearing caps starting at center, rotate bolts 1/4 turn at a time.
Remove intake camshaft.
Remove head bolts starting in center, working out.
Remove head.
DO NOT MIX UP THE ADJUSTMENT SHIMS, THEY MUST GO BACK IN SAME POSITION.
As I said a manual will be better and has pics also.
Sunday, December 20th, 2009 AT 8:08 AM
