I cant seem to get my passenger side cv joint popped loose from the transmission is there some trick to it or what?
Tuesday, April 1st, 2008 AT 5:07 PM
MECHANIC
Hi there,
The C.V. Is just located with a "C" clip, but they can be stubborn some times, just use a sutable lever between the shaft and the box, lever with a jerk action, and rotate the shaft a bit and try again, it should pop out with out too much worry.
