1986 Toyota Corolla 4 cyl Front Wheel Drive Manual
My Corolla has a new motor from japan, OEM replacement. A Toyota Re-manufactured Carburetor, new vacuum lines, new air filter, new spark plugs & wires as well as a new distributor cap. My issue is the it as a really high idle after warm up. Without a tach, I would say it would be around 1200 rpm with thermostat bypass (the hottest setting), and 1400 rpm w/o bypassing the thermostat (set to the coldest setting). The car had sat for 5 months after all the new parts, with low to no gas in the tank. Upon start-up, 5 months later, fresh premium gas and now my problem. What could be making this happen. Please Help!
SPONSORED LINKS
Monday, August 23rd, 2010 AT 12:41 PM
