1986 Toyota Corolla Car only runs for 15 seconds!
1986 TOYOTA COROLLA
150,000 MILES • 4 CYL • FWD • AUTOMATIC
PEPFATKIKI88
  • 8 POSTS
My car suddenly wouldn't start. After much troubleshooting I determined that it is not the timing, fuel pump, etc. The car turns over just fine.
If the car sits for a few days, it will run (fire in other words) for about fifteen seconds...then stall.
You have to let it sit for a long time before it will run again, but just for a few seconds.
My neighbor down the street said it seems to be a vacuum leak. While I was turning the key, he put his finger over some hoses + the car ran - I don't know exactly what he did. There are a lot of hoses under the hood - which exact hoses are the critical ones that I need to replace? I have a Haynes Repair Manual
that does not explain the whole theory very well.
Please explain what I need to do.
May 19, 2010 at 7:06 AM
Block wide open the airflow meter and start the car and see what happens.
May 19, 2010 at 9:09 AM
PEPFATKIKI88
  • 8 POSTS
What/where is the airflow meter?
May 20, 2010 at 11:06 AM
Its contain within the air filter housing
May 20, 2010 at 11:20 AM
