1981 Toyota Corolla VACUUM LEAKS
PEPSTER60
  • 1981 TOYOTA COROLLA
  • 4 CYL
  • 60,000 MILES
My car has been checked for vacuum leaks. The hoses, the carburetor, intake manifold and various smog devices. I need to know where else a vacuum leak could be coming from.
Friday, August 20th, 2010 AT 10:14 PM
Could be the vac hose to the brake booster or EGR valve-what make you think its a vacuum leak problem could be something else that's causing it.
Saturday, August 21st, 2010 AT 5:04 PM
PEPSTER60
Because my car runs great at an idle, but after it stays on for a certain amount of time and then I turn it off, when I turn it back on after 15 minutes it runs like crap. I had someone check it out, and they tried every other thing that they could think of and came to that conculsion. If you have any other ideas on where or what to do to fix this problem of mine, I would really appreciate it very much.
Saturday, August 21st, 2010 AT 9:25 PM
