1981 Toyota Corolla Head Gasket
1981 TOYOTA COROLLA
138,000 MILES • 4 CYL • 2WD • MANUAL
LUKE GARDITI
i just baught this car a week ago and the guy said it has a blown head gasket, i just want to make sure. well the car heats up really quick and white smoke comes out of the exhaust, its kind of a sweet smell. is there anything else that can be wrong?
Apr 30, 2009 at 5:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Symptoms you have are of a faulty gasket. Most likely the head gasket, yes. May want to make sure that this hasn't caused more damage internally to the engine as well.
Thanks for using 2CarPros.com!
Apr 30, 2009 at 6:33 AM
LUKE GARDITI
i took apart the head today and i say that there is antifreeze in only one of the pistons, could my head be cracked or what?
Apr 30, 2009 at 4:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If there's one piston top that's noticeably cleaner than the others (because of the coolant) then this just indicates that you have had a bad head gasket. Doesn't prove anyting else though. A compression test would have to be done to really know but most likely it hasn't damaged anything unless the vehicle has been driven past the overheating point.
Apr 30, 2009 at 4:30 PM
LUKE GARDITI
okay thanks
Apr 30, 2009 at 5:05 PM
MMPRINCE4000
  • 8,548 POSTS
You might be better off getting a reman'd head, it may be warped to the point that it cannot be machined enought to get it flat.
May 1, 2009 at 12:10 AM
LUKE GARDITI
the guy who i baught it from changed the head gasket 4 years ago and he had it machined down then
May 1, 2009 at 12:29 AM
