1982 Toyota Celica No Start No Click
RJOHNSTO
Hello my car just wont start. I checked the fuses under the hood. checked my wiring. I dont hear a clicking. it did this once before but after 10 minutes started with no problem. my battery is good. Is it my soilenoid? What can I do? I tried to pop the clutch but I cant.
toyota celica supra 2.8L 1982.
Feb 5, 2007 at 6:30 AM
  • 75,988 POSTS
If you're 101% correct with the battery and connections are good.
Here's a list for a start:
Ignition Switch
Neutral Safety Switch
Starter Relay
Solenoid
Starter
Good LUck
Feb 5, 2007 at 8:14 PM
Suggested Repair
If the battery and connections are confirmed good, check the ignition switch, neutral safety switch, starter relay, solenoid, and starter.
Conversation Summary
The owner of a 1982 Toyota Celica with a 2.8L engine reports a no-start with no clicking. The fuses, wiring, and battery were checked, and a clutch-pop start was unsuccessful. The expert advised verifying the battery and connections, then checking the ignition switch, neutral safety switch, starter relay, solenoid, and starter.
