1995 Toyota Celica STALLS
MICHAEB
  • 1995 TOYOTA CELICA
  • 4 CYL
  • FWD
  • MANUAL
  • 105,000 MILES
Hi, I have a 95 celica gt, 3sge engine, the car runs spot on until it warms up but then when you come to a stop or dip the clutch it drops revs dramatically even stalling on occasions, i've stripped the throttle body and cleaned it, including the icv, i've checked the tps is right and reset the ecu but still the same problem, its really doing my head in. I've heard its common on these engines but theres so many sensors I dont know what to try nexy. Lambda sensor maybe?
Any help would be appreciated.
Thanks Mike
Sunday, June 8th, 2008 AT 12:51 PM
Check the EGR valve, MAF sensor and the fuel pressure-also the exhaust system for restriction.
Sunday, June 8th, 2008 AT 12:58 PM
KHLOW2008
  • 41,814 POSTS
Hi MichaeB,
The O2 sensor is known to cause such problem for this model.
Monday, June 9th, 2008 AT 12:03 PM
