1993 Toyota Celica overheating
PATTYMAN
Engine Cooling problem
1993 Toyota Celica 4 cyl Two Wheel Drive Automatic
my Toyota will drive for 15 to 20 miles on some occasions even for a few days then overheat. the mechanic has checked the cooling system..no leaks, no sign of blown head gasket, changed radiator cap,serviced fan.. what next?
actually my Toyota is an Estima
May 23, 2009 at 12:22 PM
  • 75,988 POSTS
Did he replaced the thermostat if not have him do so-also check the radiator if its clogged, water pump and coolings fans if all okay get him to block and pressure test the cooling system.
May 23, 2009 at 12:26 PM
