1992 Toyota Celica Car Skipping
CBUL0131
  • 1992 TOYOTA CELICA
  • 4 CYL
  • 198,000 MILES
Plug wires and plugs have been replaced. Compression check shows 220 psi in all four cylinders. Cylinder #4 is not firing even though the plug and wire is. Could this be a bad fuel injector on cylinder #4? Any suggestions on what we could check?
Monday, November 3rd, 2008 AT 6:25 PM
Try swapping injector and see what happens-
Monday, November 3rd, 2008 AT 6:33 PM
KYLEATUSA
My Celica just did the same, it was #2. Someone told me to use a mechanics stethoscope ($5-$10) and hold it to each injector. Listen to the good ones first and then check the one you think is bad. If you hear and it is ticking, but like a higher pitch dry tick, you may have a clog in your fuel rail.
Monday, December 29th, 2008 AT 4:36 PM
