When doing a compression test on the engine what would be the normal. It is 2.2 L 4 cyl. milage is over 132,000.
May 12, 2006 at 3:32 AM
Compare compression-test results with the expected range: about 140-150 psi dry and 170-180 psi wet on the 2.2L four-cylinder.
The owner of a 1990 Toyota Celica GT-S with a 2.2L four-cylinder and over 132,000 miles asked for normal compression-test readings. The expert said dry readings should be about 140-150 psi and wet readings about 170-180 psi.
