1990 Toyota Camry Clicking No Start
BETHANY1895
i have a 1990 auto toyota camry sedan about 130,000 miles (198,000 km) 2.0 litre
it is not starting, when you turn the key you get a clicking noise
if you rapidly turn the key multiple times it will start, and it also at other times starts perfectly fine.
it has a new starter, new radiator, new alternator, new battery (all within 2 years) but is due for a timing belt soon. Wondering if the timing belt may be the cause of the problem?
not sure if its related also but often when switching from reverse to drive the power cuts out and you have to restart the car...
Feb 27, 2007 at 7:14 PM
SERVICE WRITER
  • 9,123 POSTS
The problem is not the timing belt, it is in the starting system. IE. iginition switch, battery, starter, connection.
Turning the key back and forth may be ironic. You need to see if power is getting to the starter. I would make sure all connections to and from the battery are clean and tight.
Feb 27, 2007 at 8:57 PM
  • 75,988 POSTS
Check these starter relay and the ignition switch
Feb 27, 2007 at 9:00 PM
Suggested Repair
The timing belt is not the cause. Inspect the starting system: clean and tighten all battery connections, confirm power reaches the starter, and check the starter relay and ignition switch.
Conversation Summary
A 1990 Toyota Camry with about 130,000 miles clicks and often will not start, though rapid key cycling or other attempts sometimes start it. The starter, battery, alternator, and radiator are relatively new, and the timing belt is due. Power also cuts when shifting from reverse to drive, requiring a restart. Experts said the timing belt is not the issue and advised checking the starting system, including battery connections, power to the starter, the starter relay, and the ignition switch.
