2000 Toyota Camry Bulb Out Warning Light
MINDY
Is there a reset button for the "bulb out dash warning light"? We replaced 2 burnt out bulbs, yet the warning light continues to annoy me! Its on a 2000 Toyota Camry, Manual,4-door
Thanks
Feb 15, 2007 at 1:40 PM
  • 55,815 POSTS
First, you need to make sure you have the right bulbs in please or the light will be on. Or you need to replace the bulb controller in the trunk or it's behind the rear seat in a side panel.
Feb 16, 2007 at 5:44 AM
Suggested Repair
Confirm the correct replacement bulbs are installed. If the bulb-out warning remains, replace the bulb controller in the trunk or behind the rear seat in a side panel.
Conversation Summary
The owner of a 2000 Toyota Camry replaced two burned-out bulbs, but the dash bulb-out warning stayed on and asked whether it has a reset button. The expert said the correct bulbs must be used, or the bulb controller in the trunk or behind the rear seat side panel needs replacement.
