1996 Toyota Camry Steering Knock
D B BOONE
1996 Toyota Camry, 165,000 Miles. When ever I turn, I hear knocking sounds. What could it be?
Mar 16, 2007 at 3:41 AM
MMPRINCE3000
  • 133 POSTS
Could be the CV joints (inspect the inner and outer boots for damage), inspect outer tie rods, ball joints, struts and control arm bushings.
More than likely the CV boots are leaking/out of grease. Sometimes a rock or tree limb hits the rubber boot(s) and causes a tear. The grease leaks out and water gets in and will cause rust on the CV joint, when you turn this wear will manifest itself as "clicking" or knocking. It will eventually fail. You can replace the boot, but I have found it much easier to buy a remanufactured axle with new boots.
Mar 16, 2007 at 3:58 AM
Suggested Repair
Inspect the CV joint boots, outer tie rods, ball joints, struts, and control arm bushings. Torn or leaking CV boots are the most likely cause; replacing the axle with a remanufactured unit is often easier than replacing only the boot.
Conversation Summary
A 1996 Toyota Camry with 165,000 miles knocks when turning. The expert advised inspecting the CV joints and boots, outer tie rods, ball joints, struts, and control arm bushings. Leaking CV boots that let grease out and water in are the most likely cause, and a remanufactured axle is often easier than replacing only the boot.
