1995 Toyota Camry Knocking noise when step on gas
189,000 MILES • 6 CYL • AWD • AUTOMATIC
RICKSOL
My Camry is making knocking noise whenever I accelerate. When I move my foot away from the gas pedal the noise reduces substantially. Could you suggest what may be the cause of this knocking.
Jul 13, 2008 at 9:56 AM
MERLIN2021
  • 17,250 POSTS
If it's octane pinging, you may need a better grade of gas, if it's an actual rapping, you may need engine work, most knocks are a bad wrist pin or connecting rod bearing and crank journal..
Jul 13, 2008 at 11:13 AM
