2002 Toyota Camry Stalls at Stops
Have the EGR system check
Have them check for a sticking/binding throttle plate,IACV,TPS,MAF/IAT,EGR,CTS and O2 sensors. Also get them to scan the computer maybe there's something in there that can give them a headstart.
Sorry, sounds like the whole entire TCCS
Suggested Repair
Have the shop check for a sticking or binding throttle plate and inspect the IACV, TPS, MAF/IAT, EGR system, coolant temperature sensor, and oxygen sensors. Also scan the computer for data that may help diagnose the intermittent stall.
Conversation Summary
A 2002 Toyota Camry with 60,000 miles intermittently stalls or idles roughly when stopping or in stop-and-go traffic, with no check-engine light. It runs normally at higher speed, restarts immediately, and will not die if the accelerator is pressed in Park or Neutral. The dealer could not reproduce the issue. The expert first suggested checking the EGR system, then recommended inspecting a sticking throttle plate, IACV, TPS, MAF/IAT, EGR, coolant temperature sensor, and oxygen sensors, plus scanning the computer.
