1993 Toyota Camry Leaking Rear Struts Fix
JOHN STEVENS
My rear struts need replacing on my 1993 Toyota Camry wagon (195,000 miles); both are leaking fluid, both are very bouncy. Is this a job I could do myself? I've looked at the manual and it doesn't seem to call for the coil spring compressor, but I thought I might need this. The Toyota dealer claimed the mount and bushings needed replacing as well. Are these straightforward to replace|?
JOhn
Aug 12, 2007 at 8:02 AM
  • 75,988 POSTS
[quote:34ba5e8891="John Stevens"]My rear struts need replacing on my 1993 Toyota Camry wagon (195,000 miles); both are leaking fluid, both are very bouncy. Is this a job I could do myself? I've looked at the manual and it doesn't seem to call for the coil spring compressor, but I thought I might need this. The Toyota dealer claimed the mount and bushings needed replacing as well. Are these straightforward to replace|?
JOhn[/quote:34ba5e8891]
You can do this-if the shock has springs -you need the compressor go to a tool rental. its as easy as changing a baby's diaper.
Whatever you do do not remove the center nut on top of the strut tower-only the 3-little ones.
Good luck
Aug 13, 2007 at 10:55 AM
Suggested Repair
Rear strut replacement is a DIY job. If the struts have coil springs, rent a spring compressor. Remove only the three small nuts at the strut tower, not the center nut.
Conversation Summary
The owner of a 1993 Toyota Camry wagon with leaking, bouncy rear struts asked whether the job is DIY, if a spring compressor is required, and whether mounts and bushings should also be replaced. The expert said it can be done, a compressor should be rented if the shocks have springs, and only the three small strut-tower nuts should be removed—not the center nut.
