1999 Toyota Camry Flasher Fuse
ATHOMAS1980
Do you know where the flasher fuse is located on the 1999 Toyaota camry?
Apr 2, 2006 at 10:29 AM
LOSONE
  • 1,616 POSTS
It is the turn signal fuse and is probably located in the ouside fuse panel. Go to autobooksonline.com and you can get a daigram or an owners manual were the locations are listed.
Apr 2, 2006 at 11:20 AM
Suggested Repair
Treat the flasher as the turn signal fuse and check the outside fuse panel. Confirm the exact location in the owner's manual or a fuse diagram.
Conversation Summary
The owner asked where the flasher fuse is on a 1999 Toyota Camry. The expert identified it as the turn signal fuse, said it is probably in the outside fuse panel, and recommended an owner's manual or diagram for the listed locations.
