30 amp am2 fuse keeps blowing
MSJUJU
I have a 93 Toyota Camry XLE , 4 cyl about 260,000 miles on it. When I start my car it cranks but will not start and the 30 amp am2 fuse blows every time you turn the key. the fuse runs to the ignition switch but I replaced the ignition switch and it still keeps blowing the fuse. any suggestions!
Mar 30, 2007 at 8:37 AM
BESTBET777
  • 89 POSTS
Check the wires from the fuse as much as you can for a short, very possibly the problem is in he steering column.
Apr 18, 2007 at 3:12 PM
