1996 Toyota Camry Radiator Mount Fit
PATRIXUSA
Radiator mounting
Having some front body work done on a 96 Toyota Camry SE coupe. Upper tie bar needed replacing or straightening due to being bent in front end collision. Upon inspection of work, there is space where the grooves in the radiator meet with the upper tie bar and they are offset a tiny bit.
How critical is fit between the upper tie bar and the radiator? Should I demand that the grooves fit perfectly or let this slide?
Thanks for any advise.
Feb 1, 2007 at 5:53 AM
LOSONE
  • 1,616 POSTS
The fit isn't as critical as the fact that your damage wasn't fixed properly. Thake it back and have it fixed properly.
Good Luck losone
Feb 5, 2007 at 4:08 AM
PATRIXUSA
losone, thanks for the reply. Are these gaps indicators of the repairs not being done properly? The shop had installed new metal fixtures that fix the radiator to the upper tie bar with rubber in-between, this is where these gaps appeared. Upon making note of this, the shop has since placed the original metal fixtures back on the car. The fit is much better, but, is this indicative of the repairs not being done properly or just the new parts not fitting as good as the originals?
I know it's hard to say without seeing the car in person, so, I’ll probably take it to a dealership to have them evaluate.
Thanks.
Feb 5, 2007 at 5:11 PM
Suggested Repair
Return the Camry to the body shop and have the collision repair corrected properly. The slight radiator-to-tie-bar offset is less important than incomplete front-end repair; a dealership inspection is a reasonable next step.
Conversation Summary
The owner of a 1996 Toyota Camry SE coupe noticed a small offset where the radiator grooves meet the replaced or straightened upper tie bar after front-end collision repair. New radiator mounting fixtures created gaps, so the shop reinstalled the original fixtures and the fit improved. The expert said the fit itself is not the main concern and that the damage was not repaired properly, advising the owner to take the car back for a proper repair. The owner planned to have a dealership evaluate it.
