rack n pinion
TOYOTA CAMRY
ZEIK
what is the rack n pinion? how much is it to replace?
Nov 29, 2007 at 9:14 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
The rack and pinion is the steering system, the "Pinion" is connected to the steering column and steering wheel, when you turn the steering wheel the "pinion" rotates and in turn moves the "Rack" from side to side, this is what turns the wheels left to right. The steering rack is located under the car between the body and the sub frame. It takes about 3 hrs to remove and re fit, as for a price of a rack, you will have to contact your local parts dealer as i am in Australia and i have no idea as to your prices.
Mark (mhpautos)
Nov 30, 2007 at 6:24 AM
